SMTP
NSA210 / NSA221 / NSA310 / NSA320 / NSA325
Moderator: celeste100440
SMTP
Postby AnyVey on Wed Aug 28, 2013 10:28 pm
Is it possible to get SMTP work on a different port and use SSL/TLS? Or anyone have a workaround they are using?
My ISP blocks port 25 and I don't see any option to change the port or use SSL/TLS in the settings.
NSA325 Firmware 4.6
AnyVey
Newbie
Newbie
Cash: 2
Re: SMTP - Zyxel NSA320S
Postby rma on Sat May 27, 2017 3:54 pm
There is still the problem with the lack of possibility to change smtp port.
Will Zyxell ever do it? :cry:
Firmwave v4.75(AANV.1)
rma
Newbie
Newbie
Cash: 1
Re: SMTP
Postby Mijzelf on Mon May 29, 2017 2:19 pm
If your box doesn't support it now, ZyXEL will never support it for you, as your box is EOL.
Have you already tried to specify the port with the domain? a.g. domain.com:<your-port>
If that doesn't work either, you can install Entware-ng and use emailrelay as local proxy, to forward to any port you like.
Mijzelf
Advisor
Advisor
Cash: 975
Return to Home Storage
Who is online
Users browsing this forum: No registered users and 3 guests
forum statistics View Forum Stats
cron
© Copyright 1995-2009, ZyXEL Communications Corp. All rights reserved.
