M-1 NAT on USG20
USG 40/ USG40W/ USG60/ USG60W/ USG110/ USG210/ USG310
USG 20/ USG 20W/ USG 50/ USG 100/ USG 200/ USG 300/ USG 1000/ USG 2000
Moderator: AliceShih
M-1 NAT on USG20
Postby holtain on Mon Jun 19, 2017 5:47 pm
I'm trying to replace our venerable Zywall 2 plus and these are the NAT rules I'm trying to setup on the USG20, and ideas how to do the M-1 ones?
Local Start IP Local End IP Global Start IP Global End IP Type
10.0.0.254 N/A 217.146.109.190 N/A 1-1
10.0.0.1 N/A 217.146.109.179 N/A 1-1
10.0.0.2 N/A 217.146.109.181 N/A 1-1
10.0.0.3 N/A 217.146.109.178 N/A 1-1
10.0.0.4 N/A 217.146.109.180 N/A 1-1
10.0.0.5 N/A 217.146.109.182 N/A 1-1
10.0.0.6 N/A 217.146.109.183 N/A 1-1
10.0.0.7 10.0.0.15 217.146.109.184 N/A M-1
10.0.0.16 10.0.0.30 217.146.109.185 N/A M-1
10.0.0.31 10.0.0.253 217.146.109.186 217.146.109.189 M-M Ov
holtain
Newbie
Newbie
Cash: 2
Re: M-1 NAT on USG20
Postby chaks on Tue Jun 27, 2017 12:25 pm
I have the same problem. I hope some one will give solution.
Best regards
chaks
Newbie
Newbie
Cash: 4
Postby zyman2008 on Tue Jun 27, 2017 2:53 pm
For the outbound source NAT(SNAT), you need add policy route rule.
Take your example,
The source IP 10.0.0.7-10.0.0.15 go out to WAN, the source IP will be translated to 217.146.109.184
Here the steps,
1.Create source IP address object for 10.0.0.7-10.0.0.15
Go to GUI, Object > Address. Add an object with RANGE type, give a name, and the address - Starting IP address: 10.0.0.7, End IP Address: 10.0.0.15
2.Create public IP address object for 217.146.109.184
Go to GUI, Object > Address. Add an object with HOST type, give a name, and the address 217.146.109.184
3.Create policy route for SNAT
Go to GUI, Network > Routing > Policy Route. Add a rule.
Incoming: any (or you can select the interface of the IP 10.0.0.7)
Source address: select the address object created in step 1
Destination address: any
Next-hop: select the WAN interface (wan or wan_ppp if using PPPoE connection)
Source Network Address Translate: select the address object created in step 2
User avatar
zyman2008
Senior
Senior
Cash: 211
Postby chaks on Wed Jun 28, 2017 11:46 am
Zyman2008
Man tnx a lot this was helpfull and i managed to configure network this morning in 1 hr.
Cheers
Regards
chaks
Newbie
Newbie
Cash: 4
Return to USG series
Who is online
Users browsing this forum: No registered users and 5 guests
forum statistics View Forum Stats
cron
© Copyright 1995-2009, ZyXEL Communications Corp. All rights reserved.
